I have a small hallway so I went for real wood floor opposed to laminate, I chose this floor and hope someone can answer a couple of questions.
The flooring I got is this
https://www.wickes.co.uk/Style-Garden-Light-Oak-Solid-Wood-Flooring---1-5m2-Pack/p/184314#
When we removed the old floor we had to get the floor screeded as it was rising up in the middle where a wall once was.
Firstly I have read through the data sheet in the link and it talks about if glueing then ensure the screed is rough, is there a tool I should use for this?
Secondly I’ve watched a video (done by wickes) for the floor and they spread an adhesive down and lay the floor onto this, I initially thought this would be a floating floor glued together but I’m clearly wrong.
is there an adhesive you would recommend I should use?
thanks
thanks
