Remove Alpha easy stat help?
31 Oct 2021
Hi I have an alpha intec2 28xe and the thermostat controller has gone missing.
I'm replacing with a hive but unsure of the Best way to remove the old alpha easystat which is located on the boiler.
Have wired up the hive fine but the old one needs removing for it to work.
Any help would be appreciated. Have attached boiler manual
  • intec2 25-28XE instructions and users 04-15 (2).pdf
Cheers just spotted that so joined them. All good and working thanks
What wires did you join? I’ve got same issue. Give working fine but if my old wireless thermostat runs out of batteries then give can’t control the boiler.
Sorry never knew this. Just seen it was relevant to issues I was having. Will start a new post.
