    Dismiss Notice
Removing a toilet siliconed to the wall?
Discussion in 'Plumbing and Central Heating' started by Originalgoon, 8 Sep 2017.
  1. Originalgoon
    Originalgoon
    30 Jan 2016
    7
    Thanks Received:
    Country:
    The flush valve in one of our toilets has broken and I need to replace it. I've done it before and it's not a huge job. Unfortunately, however, the cowboy who installed the toilet has siliconed it to the wall instead of using screws. They also appear to have caulked the gap between the cistern and the commode.
    I tried using a bit of brute force and it didn't move a millimetre. Does anyone have any tips on how to resolve this or should I call in a professional? I hate the idea of having to call someone in for what is essentially a simple job but will have to bite the bullet if there's no way I can do it myself.
    I've read a few suggestions to hacksaw the silicone. Would any sealant remover help?
    Any suggestions would be really appreciated.
    I've attached a picture if it helps at all.
  2. Sponsored Links
  3. muggles
    muggles
    28 Oct 2005
    12,959
    Thanks Received:
    2,916
    Daventry
    Country:
    • Like Like x 2
  4. Gorners
    Gorners
    6 Dec 2015
    167
    Thanks Received:
    5
    Country:
    Long kitchen knife from either side in a sawing motion and prepare for some graft. I've recently had to remove a couple of shower screens and siliconed to the wall and that wasn't easy, so feel your pain!
    I also believe it's a perfectly acceptable method of attaching sinks and cisterns to walls these days. Will certainly make it more secure than screws but not so good for maintenance!
    • Like Like x 2
  5. polesapart
    polesapart
    27 May 2011
    1,298
    Thanks Received:
    328
    Country:
    I disagree. Lazy and bodgy IMO.
    Who'd want to attach a sink to a wall anyway? A basin perhaps..
  6. Gorners
    Gorners
    6 Dec 2015
    167
    Thanks Received:
    5
    Country:
    I don't necessarily disagree with you. Just seems to be an accepted method from what I've seen/heard.
  7. Originalgoon
    Originalgoon
    30 Jan 2016
    7
    Thanks Received:
    Country:
    Sorry, not quite sure I follow. I tried twisting and pulling the top half out but it appears to be lodged and couple of stays have snapped off too it seems so not sure that will work anymore. Do you mean the whole thing can be snapped out?
  8. AGAS
    AGAS
    21 Feb 2014
    9,691
    Thanks Received:
    1,710
    down south
    Country:
    someone tried unscrewing the wrong way ;):ROFLMAO: they snap easy
  9. Sponsored Links
  10. Originalgoon
    Originalgoon
    30 Jan 2016
    7
    Thanks Received:
    Country:
    Lol I don't think so. Instructions online said to turn it 1/8th anti-clockwise which is what I did. Despite getting it loose though, I couldn't pull the mechanism out. Felt like it wasn't possible or there was some kind of catch I couldn't see. Instructions make no mention of it though.
  11. Get a few long blade bread knives from your local £1 shop to cut the silicone away,
    Or
    A length of cheese wire threaded around the back of the cistern and use pliers to hold the cheese wire and saw away at the silicone,works a treat.
    Also works very well removing basins,sinks shower frames or anything that has been siliconed to a wall.
    cheese wire example, http://www.gnltd.co.uk/goat-nutriti...teel-wires-for-handee-cheese-cutter-60cm.html
    • Like Like x 1
  12. muggles
    muggles
    28 Oct 2005
    12,959
    Thanks Received:
    2,916
    Daventry
    Country:
    Go and buy the new one and it should become immediately obvious how to get the old one out
  13. dilalio
    dilalio
    20 Mar 2009
    7,484
    Thanks Received:
    1,164
    Potters Bar
    Country:
    If it's CT1 you'll have to take the wall down :ROFLMAO:;)
  14. Originalgoon
    Originalgoon
    30 Jan 2016
    7
    Thanks Received:
    Country:
    Wow. What is your problem? No need to be a dick.
    For everyone else, thanks for the advice. Much appreciated. Managed to cut my way through the silicone with a long serrated knife after a fair bit of effort. Will replace the valve tomorrow, all being well.
    • Like Like x 1
  15. dreadnoughtheating
    dreadnoughtheating
    31 May 2009
    3,637
    Thanks Received:
    757
    Norfolk
    Country:
    In and out in five minutes complete with my payment...... 7 if I get the full life story.
    Fluidmaster slips straight in. Jobs a goodun.
  16. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
