Removing section of load bearing wall
16 Sep 2018
I intend to remove a section of a load bearing wall roughly 1.8m in length and install an RSJ. I would however like to have this flush ie no boxing on the ceiling. This wouldn’t be too difficult however the wall supports joists on both sides making a flush installation a bit more difficult. Is there a method to this type of installation? Any assistance is muchly appreciated, thanks
2 Feb 2006
Staffordshire
You would need to remove a section of skirting board in the rooms above and thread 'needles' through and onto the exiting joists. You then prop these needles and joists from below. You can then remove the wall below along with a slice off the ends of the joists. Enough to allow the steel to pass.
You then fill the web of the steel/s with a pair of timbers bolted through then offer the steel up. You then wrap jiffy hangers around the joist ends and fix to your timber in-fill. We try and be cute and add a layer of mortar onto the top of the flange so that it squeezes into place as it presses against the recipient bricks. Once set remove the needles and make good.
11 Jun 2018
I would get a structural engineer to spec what you want to do. Maybe two L's bolted together with notched joists might achieve the result you want.
