Replace old wc with new close coupled wc
23 May 2006
Southampton
The old wc (ground floor) is an S trap going through the concrete floor into cast iron spigot.
I want to replace with a close coupled wc. Do they supply S trap close couple ones or do multiquicks have an assortment of adaptors to fit most situations.
My worry is that the measurement of the existing cast iron drain will not let the new close coupled cistern go back to the wall.
Any tips for doing this much appreciated. :?
still can get s traps I think
but why bother when MultiKwik make so many different pan connectors
u should be apples matey
I had this problem recently , forget trying to find a wc with the same trap .
I tried all connotations of flexible connectors and nothing would work , i ended up biting the bullet , digging an area of drain up and repositioning it close to the wall .
Took about 2 hours max , prior to that I had spent days on research and making my mind up on what to do.
Yep, I'm at the 'days spent researching the thing'.
It's always my luck when I do these jobs, that something wont fit by some small margin. and no amount of pulling or shoving will make any difference (or silicone) and I wish I hadn't started the job in the first place. :)
I had exactly your problem tryitandsee.
I found out that I just could not get a toilet with an 'S' trap, so I gave up trying.
I've ended up getting a normal 'P' trap toilet off ebay which will push against the wall and allow enough space for a 90 degree pan connector which will go into the floor, or maybe you could use a swan neck pan connector (I don't have room for one of them as my waste pipe is too close to the wall).
It took a while to find one suitable but I'm hoping it will work (got the plumber coming next week ...at last :roll: )
Here is the toilet I finally found:
Nice eh :) ?
can you post a pic of the back view showing the outlet?
And the side with dimensions?
ta.
Amanda
Just the job, :) It looks like it would swallow up the eventual 'connecter' and get back to the wall.
Gives me a better idea of what to look for, thanks.
ta.
I can JohnD but I'll have to do it tomorrow cos at the mo it's all wrapped up in its box and I'm wrapped up in bed :lol:
Robert too if you dug out the pipe in the floor to take pan back to wall did you have to reinstate a type of damp proof when reconcreteing ! just curious . cheers
I did come across an excuse for a dpm , but as soon as i broke through the screed , most of what i came across was just backfill / pea shingle ,, which i replaced untill the last 150mm or so .
I did make an attempt to turn the existing polythene up , but it is on raised ground and in no danger .
If howy is trying to replace a typical late seventies contract pan , that cistern will lave a gap of about 125mm back to the wall .
No connectors will get into the typical floor outlet
Right here is the back of my new loo: - didn't want to risk putting my back out lifting it out the box.
:oops: Bit out of focus soz!
There is 18cm of space from the end of the waste to the back of the pan which will butt up to the wall. There will in fact be gaps down the side cos they do not butt to the wall as they taper.
The centre of the waste is approx 20cm high. This ought to give a 90 degree pan connector enough room to fit behind.
I bloomin hope so :?
I can't visualise where the soil pipe connector will go. Will it turn downwards? It looks like there is a section of the fireclay moulding directly underneath it which will obstruct it.
