- Joined
- 29 Nov 2015
- Messages
- 9
- Reaction score
- 0
- Country
Looking in the cupboard it was obvious to see the silver flexi hose that connects one of two expansion vessels was leaking and judging by the amount of water on the floor it had for a day or two.
I've isolated the water turning two wheels water inlets I assume. Turned on all the hot water taps and turned off the boiler.
I released most of the rest of the water turning the red PRV and the water went out through the tundish and then out of the house.
I simply want to replace the silver flexi hose to the white expansion vessel that connects to a PRV. This isn't a problem.
My concern is re-pressurising the system.
1) In what order do I re-open the valves.
2) Do I leave the hot taps on or off when doing this.
3) Which one of the two red wheels do I turn first.
Or does none of this matter
See two pictures of my system
I believe I'm right in saying the system pressure needs to be at 1bar when water system is cold.
Thanks for looking and hope you may be able to help.
Kind Regards
Lee
