Replacing laminate with carpet. Underlay?
24 Jan 2006
Staffordshire
At present in the living room we have a laminate floor that has (quickstep combifloor underlay with DPM), the missus wants to replace this with carpet so our 6 month old can crawl about.
What I need to know is what do I do with the underlay.
I know you cannot use carpet underlay for laminate flooring but not sure about laminate underlay for carpet.
Or is it best to put carpet underlay on top of the laminate underlay ? As this will keep the DPM.
Why do you want to keep a dpm?
Is your lounge damp?
Or are you trying to save money? If so then to answer your question - No it is not suitable for carpet. You should be guided by your local independant carpet retailer (who will advise you as I have have done)
No the lounge isn't damp. Just thought it may be better to keep the dpm to stop any damp forming, or will that no happen with carpet ?
If damp won't be a problem with carpet i'll just remove the current underlay and replace with carpet specific underlay.
I am sure the wood experts will confirm this....
My understanding is....
...The DPM is to protect the laminate (damp usually makes it blow), not the room.
Modern laminate is much more resiliant to damp, and it is hardly ever fitted with a DPM (certainly not common for us, our estimator only specifies it in older (cottage type) properties).
Some retailers like it because they can charge you more for it!
...I am now going to run and hide before the wood experts come and hide my battered body under one of their installations. :wink:
DPM underlay (for laminates) should only be used on a concrete subfloor !! NOT a timber sub-floor..
But there is no reason i know of why it can't stay down to save on underlay for a carpet. At 3mm thickness tho, it's not going to pass as a quality carpet underlay..
I'll hide with you Lymm when the carpet fitters arrive !!
If you are replacing laminate with carpet, an underlay is highly recommended because it improves comfort, insulation, and durability. A good underlay helps reduce noise and provides a softer feel underfoot, making the carpet last longer. If you are upgrading flooring in Dubai, choosing the right underlay is important due to the region’s warm climate and interior comfort requirements.
For those considering different flooring options, laminate flooring Dubai remains a great alternative because it is durable, stylish, and easy to maintain. However, if you prefer the softness of carpet, a quality underlay will enhance performance and comfort. Always select an underlay that matches your carpet type for the best results.
