    Dismiss Notice
Replacing Shed Roof Felt
Discussion in 'Roofing and Guttering' started by mdsdiy, 1 Feb 2016.
  1. mdsdiy
    mdsdiy
    1 Feb 2016
    3
    Thanks Received:
    Country:
    The felt has ripped off our shed roof felt in the wind and I would like to find out the quickest/easiest way to replace it.
    I've bought the felt and have found some nails in the garage (like these ones http://www.screwfix.com/p/felt-nails-galvanised-3-x-20mm-0-5kg-pack/17718) but as I'm lazy I'd rather not have to go up and hammer them all in! Are there any cheap nail guns that would take this type of nail? If not, would something like this cheap nailer work (http://www.screwfix.com/p/titan-ttb516nal-25mm-corded-nailer-240v/85214) as it says it comes with and fires 18ga 25mm Nails (are these suitable?)
    Thanks!
  2. Sponsored Links
  3. Burnerman
    Burnerman
    7 Feb 2008
    23,073
    Thanks Received:
    4,483
    Northumberland
    Country:
    The galv felt nails have a nice big head so the felt doesn't tear away......you'd get the roof done in 15 mins!
    Consider some cold felt roof adhesive to help stick the stuff down......your choice of nail gun is not much use here.
    John :)
  4. rsgaz
    rsgaz
    28 Jul 2014
    1,858
    Thanks Received:
    507
    Country:
    Instead of nails, you could screw it down with wafer head screws. They have a large diameter head like the clout nails, but so much quicker and quieter to install with a cordless drill!
    http://www.ebay.co.uk/itm/121823563634
    And if you're looking for quick and easy, then buy a sheet of EPDM rubber and adhesive instead of felt. You can get single sheets big enough for any shed size, so you only need to screw it down round the perimeter. Shed felt nowadays is so cheap/thin and doesn't cover even a small shed in one sheet, so you'll have a join where the weather will try and get in and it'll need re-doing in a couple of years time!
    Gaz :)
  5. mdsdiy
    mdsdiy
    1 Feb 2016
    3
    Thanks Received:
    Country:
    Thanks, I think I won't bother with the nail gun then!
  6. mdsdiy
    mdsdiy
    1 Feb 2016
    3
    Thanks Received:
    Country:
    I do like this idea, I've already got the felt though so will go with the wafer head screws I think! Cheers
  7. rsgaz
    rsgaz
    28 Jul 2014
    1,858
    Thanks Received:
    507
    Country:
    Just check the thickness of the shed roof timber before choosing what length wafer head screws or you'll have screw tips poking through the inside.
    Gaz :)
  8. catlad
    catlad
    29 Jul 2011
    4,850
    Thanks Received:
    737
    Lancashire
    Country:
    20mm clout nails
  9. DIYnot Local
    3 Sep 2019
    Country:
  10. Sponsored Links
Loading...
Share This Page
