Replacing siphon in old high level cistern
19 Nov 2011
Essex
When I want to flush the toilet multiple pulls of the chain is required and it is getting worse over the past few months. I was told that I need a new siphon. But as I know nothing about plumbing I don't know if this is true either so please excuse my ignorance. I do know it is old, I am guessing 40-50 years old, may be older. Trying to remember when my father replaced it.
From reading around it appears I have a "well bottom" cistern and when I remove the lid I can see that the siphon has the name "Shire" on the top of it. On the side are the numbers 185.5 ½.
In two separate circles there are the numbers 10 and 58. I don't know what the numbers mean but thought they might help experts on this forum.
From this information is any one able to tell me what sort of siphon I need to buy please. I am hoping to get a jobbing handyman to replace it, if he says he is able, but I need to try and find a siphon and I am confused by the bewidering array and don't know where to to start.
Thanks for reading and hope someone can offer some advice please.
Wouldn't be a big surprise if the 10 and 58 were the manufacture date...
As for the rest a pic or 3 would be useful. Do bear in mind when paying your handyman that you can buy a brand new close coupled toilet for less than £50....last old style cistern repair i looked at was going to cost £30 in parts alone, if you're paying labour as well.....
If you're not intending on carrying out the work, I'd recommend someone who has worked on these before, more likely a plumber. The reason being is, some of them have extra parts, like a reducer.
Photos as suggested. Do these help with identification?
1. That's not old, its made of plastic.
2. The really good old ones had an inverted "bucket" made of cast iron in a sort of bell shape.
3. Pull the handle, chain pulls the lever, lever lifts the "bell".
4. Release handle, bell drops under its own weight, forces water into flush pipe, starts syphon. Syphon runs until air comes in.
5. No diaphragm's, simple and robust.
6. Anyone remember the "Original Burlington"?
Toolstation, two sizes 5" & 4 1/2".
https://www.toolstation.com/syphon-...MIyu6FqZqb6gIViLbtCh3lSgzjEAQYAyABEgJ75PD_BwE
The height of the syphon in your pic is 8 1/2 inches.
Which is likely to be easier for a DIYer. Replacing the siphon or replacing the diaphram. Do you have to take the siphon out to replace the diaphram?
I didn't know the 8½ on the siphon related to its height. So do I need to find one of the same height as the one in this link is 9 inches high.
Would this be too high. If yes, any suggestion where I can find an 8½ inch high siphon.
