Hey guys,
I've finally decided to get rid of the storage heaters because I'd like more control over the heating (I also have a wood burner thats on most of the time so overnight the storage heaters + fire is just too much). They'll mainly be used for background heat downstairs just to keep the temperature up a bit when we get in from work until the fires on but also on the odd occasion we dont light the fire.
I currently have 2 heaters downstairs (2.4kW and 1.8kW) which are being directly replaced with a 1.5w and 1kw panel heater as well as plan to install an additional 1.5kw heater in the hallway
The existing heaters are served by a 20A DP switch so presumably this is suitable (don't need to change to an SFCU)
The additional heater will have to go on the ring main as its going to be extremely impractical to run a new radial circuit to the mounting point (it is next to an existing double socket which I was thinking changing to a single + SFCU?)
As i understand this equates to about 7A of load?
Would this be acceptable providing its not putting excessive load on the ring main? The kitchen (over/fridge/extractor) is on a separate ring although I'm pretty sure the utility room is on the ring main with the washing machine in.
One final question: The heaters have an additional pilot wire which wont be used as part of a wider system (although I might get the digital timer module for an individual heater). This needs isolating but its very vague as how to do this.
Am I OK to connect a 6A terminal block to it and then wrap it in some insulation tape and tuck it away in the spur? It doesnt draw more than 100mA. I was also going to label the flex to let anyone know there may be two supplies live so someone coming behind doesnt just cut the flex without checking its properly isolated.
