Replacing underfloor heating thermostats
18 Jun 2021
Hi all,
we moved to a house that has underfloor heating with a thermostat for each room. This makes programming a nightmare as every thermostat has its own schedule, time settings etc.
Are there any smart thermostats that can be used to replace all the thermostats (about 15 of them) and provide access via an app so it's easy to control/ change/ monitor?
The thermostats we have are the ones attached but branded 'WUNDA'
thank you!
Don’t bother changing. With under floor set the temp and then just leave it. Changing the temp won’t save you much money but will cause wild temp fluctuations. If you are going to turn the temp down only drop the temp for about 6 to 8 hours . Usually 8pm till 4am.
Looks like there’s a few options, but as John says, it won’t be cheap. 15 thermostats - must be one big house!
Thanks all, it’s good to know there is a solution. I’ll probably try replacing a couple of them and see how well it works :)
