Retrospective wall ties
26 Feb 2005
Gwynedd
I'm adding a new external door into the utility room wall. The room was once a garage, "converted" at some point by previous owners. the wall in question is two skins of brick and block with a cavity between, the inner skin having been just built up of the garage floor, but has no wall ties. I'm reluctant to try to hang a double glazed door into this without tying the two skins together for strength. What's the best way to proceed? Or am i being over cautious?
It should have had ties, but if wall seems stable, i would use small sections of wall straps fitted to the reveal, tying both skins together in that area at least.
I used some when I made a window opening into a door. They were a stainless rod, threaded with rubber on. When you tightened a nut onto the thread it pulled the rubber tight and expanded it.
Wow. Great to see you back fella.
The cavity on the intended hinge side of the door has in fact been closed by brickwork, I've now realised having removed more plaster. I forgot to say that this is currently a window and I'm opening it up to be a door and a small window, so the lintels are in place in both skins already.
The more I think about it the more I'm concerned at the other side, imagining a slamming door (its windy here) loosening the brick skin. I gather some of you think I'm over-thinking it
