    Dismiss Notice
Roof weight question
Discussion in 'Roofing and Guttering' started by Klas74, 30 Jun 2017.
  1. Klas74
    Klas74
    30 Jun 2017
    10
    Thanks Received:
    Country:
    Hi
    We're getting some quotes to get our roof re tiled at the minute. We currently have clay rosemary roof tiles and I believe they've been there since the house was built 80 years ago.
    All the roofers I've had in are recommending double roman concrete tiles. But now I've read that these are a lot heavier than clay.
    Is that true or is it generally ok to replace clay tiles with much heavier concrete tiles? I don't want my roof to cave in!
  2. Sponsored Links
  3. datarebal
    datarebal
    1 May 2007
    3,059
    Thanks Received:
    574
    Hampshire
    Country:
    Where 1 d r concrete tile is heavier than 1 clay plain tile. per m2 the concrete double roman is lighter. not the other way round.
    • Thanks Thanks x 1
  4. Mw Roofline
    Mw Roofline
    30 Oct 2005
    3,160
    Thanks Received:
    339
    Birmingham
    Country:
    Just bear in mind how different the house will look with the larger tiles. Many people are spoiling the look of their traditional houses by slapping these big tiles on instead because A: They're cheaper and B: It's so much quicker and easier for the roofer to fit and they make more money by doing it this way.
    • Like Like x 1
  5. chappers
    chappers
    27 Aug 2004
    3,254
    Thanks Received:
    357
    Country:
    To be fair they should be charging a different price
  6. datarebal
    datarebal
    1 May 2007
    3,059
    Thanks Received:
    574
    Hampshire
    Country:
    As above , m2 they are cheaper, faster but the rate for fitting is less.. bit like upvc i guess :)
  7. Sponsored Links
  8. Klas74
    Klas74
    30 Jun 2017
    10
    Thanks Received:
    Country:
    Thanks for replies. I do agree, concrete won't look as good as the original type of tiling but if it does the job, lasts for years and won't make the roof cave in that's the way I'll go.
  9. ^woody^
    ^woody^
    3 Sep 2006
    31,559
    Thanks Received:
    4,228
    West Mids
    Country:
    Have your roofers mentioned that you will need a building regulations application for this type of work? The inspector will then agree if the tiles are suitable for the roof, and you will also need to insulate the loft if its not up to current standards.
    You could also select a concrete tile that looks more like the existing.
    Some older rafters can start to bow when they have had new concrete tiles. This tends to be gradual process, and by the time it is more noticable, the roofer is long gone. It then gets picked up on a future house sale.
  10. Klas74
    Klas74
    30 Jun 2017
    10
    Thanks Received:
    Country:
    No mention of any applications - I'm not in a conservation area or anything, is it normal to have to do that?
  11. ^woody^
    ^woody^
    3 Sep 2006
    31,559
    Thanks Received:
    4,228
    West Mids
    Country:
    More than normal, it's a statutory requirement - ie law!
    This is building regulations, not planning regulations.
    It's always a very good test of any builder if they mention what regulations apply to the work that you propose. And if they don't know, or deny, or the more imaginative their response as to why you should not apply, then the greater the reason not to use them.
    And the responsibility for non compliance or not applying for approval, is yours as the owner, not the builders.
    • Thanks Thanks x 1
    • Like Like x 1
  12. Klas74
    Klas74
    30 Jun 2017
    10
    Thanks Received:
    Country:
    Thanks for the info woody
  13. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
