Hi all,
I've successfully ran Ethernet cable from an unmanaged switch in the loft to most of the upstairs rooms, but I'd now like to have a cable run from the loft down to beside my BT master socket (on the ground floor). Not as simple.
The house is a new build with drylined (dot and dab) walls. Pretty sure I can negotiate the dot and dab to route a wire down, but getting it through the upstairs floor I've no idea where to begin. I lifted the upstairs carpet and the floor is what looks like particle board, which doesn't look easy to lift.
Any ideas, or would it be easier to get a sparky in just to run the cable?
Cheers,
Gareth
Cheers,
Gareth
