At risk of being shot down here, 'ring final' is simply a bit of industry jargon (in fact, a sloppy contraction of the proper jargon 'ring final circuit'). Most dictionaries appear to give the meaning of 'ring main' as being what you call a ring final, whereas few dictionaries appear to include 'ring final' (or 'ring final circuit') at all.In electrical definitions the correct term is ring final.
True, but what you didn't mention is that it also says:If it a ring main then the Oxford English Dictionary states:
"A ring main is an arrangement of pipes forming a closed loop into which steam, water, or sewage may be fed and whose points of draw-off are supplied by flow from two directions. "
...which is almost there (and, in passing, a supply arrangement which I doubt exists!), and then more-or-less gets there with:"an electrical supply serving a series of consumers and returning to the original source, so that each consumer has an alternative path in the event of a failure."
..and the Oxford Advanced Learners' Dictionary says:"another term for ring circuit" (which, in turn, it defines as: 'an electric circuit serving a number of outlets, with one circuit breaker in the supply.')
All trades and professions have their jargon, if not almost 'languages ' of their own, which is fine, and I guess that purveyors of ludicrous electrical supplies probably ought to use it - but, as I'm often saying in relation to posters in this forum, one never can or should assume that the general public are in on such things!an arrangement of cables that allows electricity to be supplied to a series of places from either of two directions
Kind Regards, John
