Sanding flap wheel for a die grinder ?
26 Sep 2007
NE Northants
Is it possible to get a sanding flap wheel thingy that has only a 3mm shaft so it will fit in a die grinder ?
I know that they are readily available for power tools but the shaft is thicker.
My local ( only ) DIY store doesn't have any so if any model making enthusiasts can point me in the right direction to buy on-line then please do !
Brian
I bought a load a couple of weeks ago at a model engineering exhibition for 50p each, can't recall who the stall belonged to, will see if I can track them down for you.
Failing that Bibielle do a range of flap wheels on 3mm shafts, look at J&L's virtual catalogue page 762.
Jason
Have a look at anywhere that sells dremel stuff.
A lot of the DIY shops do dremel accessories.
