- Joined
- 12 May 2007
- Messages
- 292
- Reaction score
- 2
- Country
I fitted a cupboard door under my stairs, the screws in the top butt hinge on the door are forever working loose. Is there something i can put on the screws to lock them in the soft wood frame
If the screw head is large enough you can pin it with a brad to prevent rotation.The door is not too big, everything is in line and there is no fouling at all, maybe longer screws would be better. At work you tie wire bolts together to stop backing out, is there a screw you can use that has some sort of anti rotation facility on it.
