I am about to clad a shed frame. I was going to use 12.5mm T&G boards, but then got worried about expansion and contraction. Will they be ok or should I use Shiplap instead?
Ultimately I would say it will come down to the quality of the timber in the first place. Given we're talking 12.5mm thickness, my initial sense is there could well be a decent amount of expansion and contraction to factor in. You can help yourself out by treating the wood appropriately (I usually use a couple of coats of wood preservative following by 2-3 coats of decking oil), but you'll still expect some.
For most sheds, I would go with shiplap - it's typically not much more than T&G and is arguably better suited. That being said, I'd rather take decent T&G vs low quality shiplap any day!
