Just bought these to put up a long oak shelf which will work as a breakfast bar. Brackets Link
I would have thought the long side of the bracket would go against the wall to provide the most strength, however the pre drilled holes in the bracket suggest otherwise as they are 9mm in diameter on the short side but only 6mm in the long side.
Would I be better drilling the short side to the wall as it can therefore take larger screws?
If it matters, it will be against a brick wall. What screws and wall plugs would you suggest?
