Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
I'm sorry, but I'm still clueless Please forgive me as I am not in the building trade.
I can see that the yellow tape does not conduct electricity, and the grey plastic on the cable would insulate the wire. That's the extent of my knowledge.
If the plumber were to say "it's not finished yet", what exactly would he use as this 'electrical insulated material'.
Electrical separations would be the ideal step to take, but plastic containment like conduit or trunking would do the job.
There also concerns that the electrician has not performed their tasks that well either. As the cables have not been support and there seems to be evidence of cables routed outside the safe zones (Assuming they are positioned closer than 50mm to either wall surface?)
The response from him was along the lines of: "he's a good electrician, and it's close enough. Don't worry, he'll sign off the work as he is qualified."
What can I do if the person who signs off the work is the one who has done the questionable work in the first place?!? Of course he wont not sign off his work. Catch-22.
I am a bit frustrated here because you folks have a lot of knowledge about what is right and wrong, and I have learnt so much from you (I am grateful). But as a paying customer I feel there is nothing I can do to hold the electrician and plumber to account. They sign of their own work.
Sorry about that rant. I'll shut up now. (Thanks for listening.)
You need to raise your concerns in writing. then if they don't respond contact their registration body (sparks have several so you need to know the one they're registered with). Gas Safe is the only one for Gas work.
Explain that is the last resort but your concerns are compelling you to act. I suspect that the mere asking for contact details of the registration body will either sharpen their senses, or cause a downing of tools... Neither is a bad outcome if it means the work is done right.
Ultimately, you're paying for the work - so it is to be done to your satisfaction.
I've redone work in the past when the customer wasn't happy. We've all made mistakes.
As above the electrician will be (or should be!) a member of a scheme provider if they are self notifying the work (Notification is different to self certification).
Notification is provided to building controls and only scheme members can do this. http://www.competentperson.co.uk/
Just about anybody with the knowledge of filling the electrical certificate can fill the certificate in, they don't even have to be a qualified or registered electrician.
So don't get confused the electrical certificate is different from the notification compliance notice.
So your concerns can be raised with the electricians scheme provider, they do
have a complaints procedure.
But your other option is to address your concerns with building controls as the installation does not comply to BS7671, which building regulation part P does ask this standard to be complied to.
I would also be having harsh words with the architect, they are letting you down regarding the standard and the compliance of the work.
I would also like to add, if the architect thinks it is OK, for the electrician to sign off the work and lie on their documentation, then someone wants to have a serious word with them!
And if the architect considers the electrician as a good one, they would not expect them to lie and the architect really needs to raise their standards!
