L
longdogs
Hi
I have had a long lasting problem with a customer's electric shower. I didn't install the original shower which worked fine for about five years but when the shower went wrong, I installed another like for like. At the same time, her water company fitted a new water meter.
The shower suffers from low pressure which means that it goes cold during use.
The shower has been checked by Triton - Apparently all ok
The water pressure has been checked by the water company - All ok
I have changed the original plastic pipework for copper (larger bore) and replaced a couple of valves which were not full bore.
So with all the plumbing changes made, there is still the same problem.
My question is: Could the pull switch be causing the problem? When the shower is first switched on, the low pressure light comes on feintly. Is it worth changing the switch. I'm really running out of ideas now.
The shower is 10.5kw and uses 10mm cable
Many thanks
Many thanks
