Im building this shower cubicle in my new extension, walls are studwork, 12.5mm plasterboard and skimmed. The new stud partition visible will have cement board attached. The shower tray will be on risers so the waste can run above the floor.
I'm looking at the mapai waterproofing kit from toolstation (significantly cheaper than screwfix at the mo!).
I've got a question regarding the shower tray.
The PDF I've found online for the waterproofing kit says to rough up the edge of the shower tray and attach to the wall with the waterproofing tape. My plan was to waterproof the enclosure and floor / wall joins and THEN fit the shower tray, sealing it in with mastic. Then getting it tiled and then mastic the tile / shower tray join. The theory being that if the shower tray / wall join does weep slightly over time then the floor and few inches of wall below it are waterproofed.
I'll be doing the work myself, and getting a tiler (that I've used before) to tile the cubicle at the same time as the bath and sink splash backs.
Thoughts?
