Single light - two PIRs
4 Dec 2011
Lancashire
Hi all
Our outside light with integrate PIR is past its best and doesn’t really function how we want it to.
it’s connected via an external Wiska box to a switch inside the house.
What I’d like to do is have a light come on when either one of two separate PIRs is triggered, one located at each end of a path.
Is this just a case of taking two cables from the terminal block in the Wiska box - one to each PIR and then take the output from each PIR to the light?
Thanks.
Yes, IF you can access the wiring in the light by-passing the existing PIR.
If not, you will need a new light as well.
