hi all i want to put power into my garage to run a tumbel dryer and a small chest freezer with a coupel of lights in it and was wondering wat size of cabel i would need to this would be gratefull for any info
.....and would be better if knew loop impedance at origin too.
My goodness - am I too conclude that whatever BAS has is catching?Design Procedure
Determine the design current Ib
Select the rating of the protection In
Select relevant correction factors... etc....
I would say the easiest way to do this (assuming you live in a regular sized house) without doing any long calculations and having to worry if the cable will be big enough etc is to wire a ring main circuit from your consumer unit to the garage i.e.
A 2.5mm twin and earth cable from your consumer unit, into the garage and then to your first socket (tumble dryer)
From that socket to the next socket (fridge freezer)
Then from that socket to a switched fused spur (for lights)
And finally back from to the board.
For the lights take a 1.5mm twin and earth cable from the outgoing side of your switched fused spur to your light. (for more lights just loop from the first to the second light and so on)
Hope that helps.
No, as far as I am concerned, telling people how to plan and do a job properly is fine, even though some here might suggest that one shouldn't do that if one feels the op is not competent to do it.What, do you mean planning and doing a job properly?My goodness - am I too conclude that whatever BAS has is catching?![]()
I presume that is a reference to me. As I've just explained to TTC, I was not 'complaining' (if that's the right word) about saying to how to do a job properly (which I fully support) but, rather, about explaining how to do the job properly, but deliberately using language which one expects/hopes the op will not understand (with, I assume, the motive of making an entirely different pont).... someone complains about that person saying how to do the job properly ...
Then DIYing is unrealistic.I would agree that really we should measure the ELI and testing and inspecting is very important. But I think to expect a DIY guy to hire the test set at £75 a week is unrealistic.
There's also the issue of whether the freezer will work properly in the lowest ambient temperatures it will experience in the garage.The freezer in a detached out building worries me. RCD's do trip and one needs to know it has tripped.
