Not so much the 45 degree on the jigsaw more it doesn't poetically skate across the wood - quite heavy handed (it's a decent one mind, but for smaller intricate jobs not so hot).
I have just managed to get hold of a coping saw.
Sorry - some of the terminology is reminiscent of my spanish classes!
I'm still not entirely sure whether I should mark the profile from a flat end grain or a mitred 45 degree piece - would there be any difference anyhow? Essentially, on two pieces of wood for an internal piece - 3 of these will be flat cut (one of those scribed) and the other mitred at 45 for the external? I apologise if I'm chasing a parked car here but I want to eliminate any margins of error (the walls are fairly tipsy at the bottom!).
all you do is mitre it at 45 exactly the same as if its going to be a mitred join then cut the profile off the exposed grain on the bit your using
[you disgard the 45% offcut]
you could do it with an offcut to mark the line but not easy...
