Despite what he wrote, I cannot see that his article can "show that" anything - it is merely his interpretation/opinion.It's a matter of opinion. I note, for example, that Mark Coles wrote the following a number of years ago in the IET Wiring Matters publication: "Some installers are of the opinion that when adding to an existing circuit, provided that the existing circuit meets the requirements of BS 7671:2001(2004), i.e. the 16th Edition, then the 17th Edition simply applies to the new addition. This article shows that in all cases, the 17th Edition is to be applied to the entire circuit worked on."
However, I've already said that, in the case of RCD protection of sockets, if they want a requirement for RCD protection, it would probably have made more sense if they had explicitly required that the entire circuit be RCD-protected if anything were added to it. Although I take BAS's point about the need to manage transition periods (after introduction of new requirements) 'somehow', to require one out of maybe a dozen or more sockets on a circuit to be RCD protected does not really sit well with common sense - particularly since providing RCD protection for the entire circuit will often not be much more difficult, and not necessarily appreciably more expensive, than providing RCD protection for just one new socket.
Kind Regards, John
