    Dismiss Notice
socket in garage has failed .....
Discussion in 'Electrics UK' started by teddyb, 31 Aug 2013.
  1. teddyb
    teddyb
    26 Nov 2006
    146
    Thanks Received:
    Somerset
    Country:
    Hi
    We have a double socket just inside the garage which has been there for about 7 years. Always had armoured cable going to the summer house below it and an RCD above it.
    The socket has stopped working and I can't see why. I have replaced the actual socket front but no joy. There is power getting to the RCD (red light comes on and goes off with the test button) but the sockets won't work and neither does anything in the summer house.
    Can anyone suggest what I might try next?
    Thanks,
  2. Sponsored Links
  3. PrenticeBoyofDerry
    PrenticeBoyofDerry
    30 Jun 2009
    21,627
    Thanks Received:
    2,382
    Londonderry
    Country:
    A little further investigation, using an approved voltage meter will go a long way to figuring your problem out.
    Does the RCD protect the socket?
    Have you picture or two of what you have?
  4. teddyb
    teddyb
    26 Nov 2006
    146
    Thanks Received:
    Somerset
    Country:
    Yes the RCD protects the socket and the armoured cable. I'll try and get some pictures.
  5. PrenticeBoyofDerry
    PrenticeBoyofDerry
    30 Jun 2009
    21,627
    Thanks Received:
    2,382
    Londonderry
    Country:
    It could well be that you have power going to the RCD unit, but not coming out. Could be a connection that has come loose on the load side of the RCD.
  6. teddyb
    teddyb
    26 Nov 2006
    146
    Thanks Received:
    Somerset
    Country:
    Thanks I will look at that. Meanwhile hear is a photo of what is on the wall
    (At least I hope this displays as a photo, if not, I haven't yet worked out how to do it! :) )
  7. teddyb
    teddyb
    26 Nov 2006
    146
    Thanks Received:
    Somerset
    Country:
    let's try again
  8. teddyb
    teddyb
    26 Nov 2006
    146
    Thanks Received:
    Somerset
    Country:
    I can't be doing this as well as the failed socket!! :evil:
  9. Spark123
    Spark123
    2 Jun 2005
    14,841
    Thanks Received:
    474
    Cumbria
    Country:
    I think you must have done something in your privacy settings
  10. Sponsored Links
  11. EFLImpudence
    EFLImpudence
    7 Jul 2010
    36,820
    Thanks Received:
    4,121
    Retired to:
    Country:
    Portugal
    [​IMG]
    • Thanks Thanks x 1
  12. Taylortwocities
    Taylortwocities
    28 Jul 2006
    20,374
    Thanks Received:
    2,105
    Oxfordshire
    Country:
    Have you checked the fuse in the RCD?
    It may be on the output side of the RCD
    Otherwise you'll need a multimeter or a two probe test indicator.
  13. teddyb
    teddyb
    26 Nov 2006
    146
    Thanks Received:
    Somerset
    Country:
    Yes, I have checked the fuse in the RCD, but I don't have any testing equipment. :(
  14. teddyb
    teddyb
    26 Nov 2006
    146
    Thanks Received:
    Somerset
    Country:
    So, EFLImpudence, how did you do that????
  15. PrenticeBoyofDerry
    PrenticeBoyofDerry
    30 Jun 2009
    21,627
    Thanks Received:
    2,382
    Londonderry
    Country:
    [​IMG]
    Its magic ;)
    So does the incoming supply enter up or downwards? it still maybe that the RCD unit does not protect this socket.
  16. EFLImpudence
    EFLImpudence
    7 Jul 2010
    36,820
    Thanks Received:
    4,121
    Retired to:
    Country:
    Portugal
    I have a friend at GCHQ.
  17. teddyb
    teddyb
    26 Nov 2006
    146
    Thanks Received:
    Somerset
    Country:
    Hah! Hhhmm.
    The incoming supply comes down from the ceiling, into the top of the RCD, then on down to the socket (which doesn't work) and then on down to the armoured cable and summer house (which has no power either, at the moment.) Last week everything was working!!!!!!
Loading...
Share This Page
