Socket stuck fast in spark plug well!!!
29 Aug 2011
Suffolk
Hi all,
I wonder if anyone can help with clever techniques... some relatives were replacing the spark plugs on a Golf and as they tried to remove the old plug the socket became stiff in the well. They persisted, thinking that it would free itself but it just bound tighter and tighter. It's now stuck rock-solid in the well. We don't know if the plug is still threaded or if it's come out. It has certainly come out part way but we don't know if its threads are free of the cylinder head threads.
Anyone known this to happen? Any ideas of what to do?
I've replaced the top end of a Zetec engine in the past and done loads of motorcycle maintenance - so not entirely new to spinning spanners. I wasn't there at the time but my guess is that the socket was somehow scraping the inside wall of the well and removed enough material that has now filled the space between the socket and the well, jamming it solid. That's just my guess.
We tried to get a grip on the socket and just drift it up out of the well (slide-hammer style) but it's stuck in too tight. I cut a piece of wood and inserted it into the square fitting of the socket and then screwed a big wood screw into it - trying to get a firm grip like a wall plug in a wall. It just wasn't strong enough. Nothing else we tried worked either. We have ordered a couple of tools that should get a better grip on it but they won't come for a day or two.
Meanwhile... any better explanations as to what's happened? Seen it before? Any clever tips on what to do??
Many thanks!!
