W
walkern
Hello,
I'm attempting to lay the soil pipe and inspection chamber on part of my extension myself (a new toilet) so did a few calculations and below is my toilet, two inspection chambers and the main sewer outlet that I believe I need to accommodate the change in directions.
From what I've been reading you should aim for 1:80 and 1:110 degree drop and inspection chambers ideally 30cm below surface.
The existing sewer outlet (the pipe I have to join) is 40cm below surface. Doing some calculations on this 11.2m run if I have the first shallow inspection chamber at 30cm it gives a 1:112 drop (i.e. 0.1m across 11.2m). If I change it to 20cm or 25cm it goes to 1:60 ot 1:75 I believe.
Is it ok to make the first inspection chamber this close to the surface (presuming you can cut them as most seem to be 30cm depth) or would 1:112 be ok?
Thanks.
Thanks.
