Helping out a friend, having basic electrical skills. Replacing stand alone cooker with separate oven and hob , using an existing cooker switch fed by 6mm cable from a 30amp fuse from a dodgy old fashioned fuse box. Have advised him to get this replaced with a new consumer unit so all work will be checked out when this is approved by local electricity supplier. However need to get cables ran so I can get on with the plastering. Am I right in thinking that I can run the 7kw hob from the cooker switch using existing 6mm cable and taking the 2.7kw oven (using 1.5mm heat resistant flex connected) off the ring main using a fused connection unit. It's only a small flat so there are only about a dozen outlets on the circuit. Or is it better to run a new cable and use a dedicated fuse from the consumer unit for the oven since we can build in the capacity anyway, is that overkill? , and what size cable and breaker should be used if so. Any advice would be much appreciated, cheers.
