spot the problem? sparks
17 Aug 2008
Edinburgh
probably seen this done about 6 times.
white cable is 6mm t+e feeding shower
a little knowledge can be a dangerous thing!
The henleys off the Main switch in Double Insulated
Two twin and earths coming off the henleys.
One is Feeding an rcd rather than a Rcbo
Has the 'installer' even managed to split the stranded CPC to link it to both the old rewireable CU and the new RCD enclosure? :lol: There's certainly something odd going on with the earthing below those henleys. Either that or it's just both CPCs through one sleeving. In any case, an A1 install apart from that!
I think the henleys are doubled off the incomer on the main CU (if you look closely there's two tails into it) then the two T&E's from the henleys feed the mini CU and switchfuse. Im guessing the main supply comes into the main CU through the wall from a meter box outside?
Edit - I wouldnt mind betting that the tails into the henleys used to feed the metal clad switchfuse until the mini CU for the shower was added.
