I have very little experience of working with electrics, but am keen to do basic jobs myself in order to teach myself something and to avoid paying an electrician for jobs I really should be able to do myself. As such, I apologise in advance for what is probably a very badly explained basic question.
I have 13 50w halogen spotlights in my kitchen which run off 2 dimmer switches. Each light is connected to its own transformer before the mains. In the 6 years they have been in place I have needed to change the transformer in 2 of the lights. One of these lights however is on about its 4th transformer and despite having changed it in the last 2 months, it looks like it has gone again as there is no current coming through. (I'm not sure if the light fittings were put in incorrectly, but pulling them down seems harder than it should be and always results in pulling down some of the surrounding plasterboard, which then needs filling, hence changing this regularly is getting annoying).
Anyway, given that the transformer in this light is regularly failing I am concerned there may be an underlying problem.
The first time it failed, it was obvious by looking at it that it had failed (there were burn marks). Since then the there is no visual evidence, but replacing has always fixed the issue.
The transformers I currently use are from Tool Station (dais, DA-E60, 20-60W / VA Dimmable Electronic Transformer) Product Number 55497. I have used these transformers in my bathroom (only difference there being there are only 4 lights controlled by a single switch and they are not on a dimmer) and they have worked fine. Also the first time I changed the transformer I used a different brand (but can't remember which one).
In short, I suppose I have the following questions:
What makes a transformer fail?
Should I try using a different better transformer? If so please can you recommend one?
Is there any chance that I am using the wrong type of transformer? (or would it simply not work from the outset if that were the case?)
Any other advice / suggestions would be gratefully received.
Thanks to anyone who has read this far, and apologies again for my obvious lack of knowledge on this subject!
Lee
Lee
