This needs hiding as its pretty ugly and as you can see right behind our tv. Not quite sure what to do but with a few ideas I am sure I will think of something
Hi there ,i have the same thing with rad pipes so i boxed them in with plywood and painted boxing with wall colour,looks much better than bare pipework.good luck with whatever you choose .Steve
I had some gas work done on a property recently only to be told that gas pipes shouldn't be boxed in according to the "rules" nowadays. Something about it leading to a build up of gas should there ever be a leak.
Ask the question in one of the other forums and you will probably get a definative answer.
If it is a gas pipe, No Do not even look at it! Don't even think of touching it, let alone painting over it! How dare you painted a gas pipe, it should be clearly marked with a warning label Gas pipe!
Seriously you have committed a serious criminal offence, you just hope H & S executive don't knock on your door early in the morning and give you a rude awakening !
Just do what you think is best, cover the ****in thing it looks real ugly!
Cover it with some tall decorative object, something that distracts your vision and so you don't notice it is there, I am sure you could use you own imagination.
anyone of the suggestions above,personally i would do as joe says and use a corner fillet.then paint it,it will look less intrusive once youve done that.
