Super Strength Glue
19 Jul 2004
Can anyone recommend a really strong glue to attach bits of wood (1 inch cube) along the top of a pvc window frame. Once dry I want to screw some curtain supports onto the wood to hang a curtain rail. I've tried various self adhesive tape, superglue and epoxy glue but nothing's working. The curtains are a couple of kilos (about 5) so it'll really need to stick.
Cheers,
you would do better with screws.
if you don’t want holes, you may be better with a window length baton giving greater surface area.
Thanks, I did think of a having a long baton but just don't want to use screws.
if you have around 250mm wall each end then 4x1"[93x18mm] attached above on the wall with no nails along the window and two rawplugs beyond the lintel each end
