I want to swap the radiator in bathroom with a heated towel rail and want to know if there is anything else I need to consider.
The pipe center is the same so I'm assuming I can just change the valves and put the towel rail on. I have a combi boiler and assume I will have to drain the system to change the valves.
Is it as straight forward as that - draining the system, changing the valves, fixing the towel rail on and refilling the system?
Many thanks...
Many thanks...
