ferdinanddebargos said:Light is a sealed unit. Previous poster is correct in saying whole thing is on a flex to enable bulb changing. Main thing is to make sure you have a water tight seal around the lights housing (sunk into the pool wall) or you will lose pool contents into surrounding earth.![]()
i presume you meant to say no more thanFWL_Engineer said:The Light MUST be rated at more than 25Vac, in all likelyhood it will be 12V.
