- Joined
- 1 Nov 2022
- Messages
- 6
- Reaction score
- 0
- Country
Hi all,
I am looking for support with a few things that happened with my alarm system. It's a Premier Elite 64, all wireless, left by the previous owners of the house. I had it serviced a two years ago and since I am learning bits on my own and with the help of this forum.
A bit of background: Basically the panel lost power and ended up depleting the internal battery, and when I turned it on I started having issues with a sensor, a 'radio not ready wait b/f arming' error appeared on the keypad, and on the texecom app its icon under devices was purple. After I removed the cover and replaced it, it seemed to have sorted itself, then the same happened to the bell, and whilst I was checking the signal strenght the keypad froze and silly me, I removed the battery to restart it. I then relearned the keypad via cable to the panel, but realised that all of the sensors disappeared, so I relearned them all.
Now the questions:
1. rather than relearning them all, would there have been a way to restore them on the system? I ask because one of my sensors I believe has a depleted battery so I could not learn it there and then, but when I check on the app, it is still listed under devices, even after many panel syncs ( through the app)
2. I also have two RKP listed on the app, but I only have one, how do I remove the old one? I checked all the zones on the keypad and there's nothing I don't recognise. Could it be because I relearnt the keypad on the same zone as before?
3. What zone type should I assign to the keypad? It automatically gave an entry/exit 1, and guard access to the main door, but then opening and closing the door does not arm the system, even with the entry/exit2 (E) attribute to the door, so I ended up giving the Entry/exit2 zone type to the door and it works fine.
4. If any has knowledge of the microshock ricochet, this is the sensor I can't yet relearn, as everytime I place the battery it's stuck on steady blue led, am I right to think that the battery needs changing?
Thank you all for your time with this.
Now the questions:
