Thermecon Boiler help please
9 Feb 2010
Herefordshire
I have a Thermecon floor mounted oil fired boiler, not sure of the model, would Minor 1 40/80 be right? Moved into our house 2 years ago and had no problems, however it was serviced in Dec 2009 and immediately started going to 'lock out'. Took front off unit and pressed the button and and it started working again. The engineer replaced a fire valve and this seemed to sort it for a few days however since then it has locked out increasingly frequently. Know it runs 20 mins max and isn't always coming back on when lockout button pressed. Boiler man looked at it last night and said everything seemed to be working and was going to make a few calls. just wondered if anyone had any ideas and also do they know where I can obtain instructions. Any help would be appreciated.
It really sounds ominous if the thing was serviced in Dec 2009 and started to fail immediately afterwards....it makes one wonder what was actually done?
It needs essential checks, like fuel pump pressure to begin with, followed by a smoke test and flue gas analysis if the burner should oblige by running long enough. After that we need to look at the electrode setting and photocell operation before going in deeper.
If it has a balanced flue, try removing the pipe trunk or leaving the burner cover off so that it can get plenty of air.
John :)
I tought it was a bit coincidental that it started playing up as soon as it was serviced. This morning i set it quite high (80) and it ran for an hour then stopped at 7 O'Clock. Still can't get it on again at 7:45. Seems it needs to cool down beofre it will run again.
