Thread size on old coughtrie lights
14 Dec 2008
This forum was able to help me a couple of years back identifying the thread size of some old BA screws in an old light fitting I had brought. Now I've been buying more old reclaimed lights....
This time I have some old Coughtrie bulkhead lights. I am trying to find the size of the inlet thread which would take a cable gland or conduit. The lights have a female thread integral to the outer casing. One of them had an old male adaptor screwed in, which I have removed and measured.
I measured the OD of the male thread at 18.75mm, which is pretty close to 3/4"
I only had about 3 threads on this adaptor, but with a bit of extrapolation I've calculated about 19TPI. Or a pitch of 1.3mm if its metric.
Threads I can find which are close are 3/4 UNEF - which seems a pretty niche thread from America and I cant find much about it in relation to electrical conduit. I was expecting something UK.
Any ideas?
thread spec actually is on old 3/4" imperial electrical conduit
Imperial conduit was 3/4 inch nominal OD, but will under-read when measured as the threads have rounded tips. But 16tpi.
BS 31
The heavyweight galvanised iron stuff? Sometimes called "gas-barrel conduit"
I've never checked, but I always believed it to be a BSP thread.
The notional size used to be measured by the internal bore, so half-inch would be about three-quarters external, where it was threaded.
Subsequently the thickness of the metal was reduced, so none of the diameters matched the name.
I had a few of these and, if you don't mind harming the 'heritage' of the fitting, they tap out pretty easily to 20mm to accept modern fittings. Later and current models have a metric thread anyway.
