Tile levelling system with wider grout lines
17 Jan 2016
I'm looking for some advice around tile levelling systems. Anyone got any ideas on which system would be best with trying to achieve a 5mm grout line?
The usual suspects seem to go up to 4mm, there is the twist one that can be used with 5mm spacers but they look fiddly.
Can the usual suspects be used with an old fashioned spacer to achieve the correct gap?
Thanks for the advice.
T
Yup! :)
As per Vitrex instructions:
https://www.vitrex.co.uk/products/lash-tile-levelling-system/
Awesome, thanks. I missed that, would have saved me blooming ages googling around. So much easier than those twisty ones I'd have to buy from Italy.
Thanks again,
Tim
IME you're way better off using the levelling clips + separate spacer anyway.
Buy the thinnest levellers - they break off easiest and and more reliably.
