    Dismiss Notice
Tiles protruding from the wall - tidying it up - with pics
Discussion in 'Tiling' started by johnagall, 10 Jan 2012.
  1. johnagall
    johnagall
    11 May 2011
    118
    Thanks Received:
    London
    Country:
    Hi all,
    Absolute novice here, please forgive me if I'm being very green!
    I recently had some work done in the kitchen and it was decided that tiling onto the old tiles was the best solution (price/amount of time ripping out and replastering/new tiles etc)
    Whilst the guy has done his best to tidy up the work and make it neat, I'm conscious that the tiles are protruding out quite a bit.
    Is there some way of adding some sort of beading tp the work to smarten it up and to make it look less obvious on the eye?
    Here are the pictures:
    [​IMG]
    image hosting
    [​IMG]
    free image hosting
    Many thanks in advance
  2. tictic
    tictic
    6 Oct 2009
    1,419
    Thanks Received:
    172
    Glasgow
    Country:
    Look in to fixing a tile trim....square/straight/round etc....genesis is the first one that pops to mind....
    Also with tiles already fixed you may need to go for a plastic trim and cut the back off with a Stanley blade and fix on with silicone...if going done this route make sure you get one thick enough to cover the tiles.
  3. johnagall
    johnagall
    11 May 2011
    118
    Thanks Received:
    London
    Country:
    So the tiler should have fitted this whilst doing the work?
  4. tictic
    tictic
    6 Oct 2009
    1,419
    Thanks Received:
    172
    Glasgow
    Country:
    Did he supply the tiles..?
    Yes...then he should have advised you about t/trim...
    No...you supplied them,without t/trim,then he may have thought you didn't want to use one,but he should have double checked with you....
    Have a had a few weird requests over the years re:tile fixing mate....
  5. johnagall
    johnagall
    11 May 2011
    118
    Thanks Received:
    London
    Country:
    I supplied but I really am clueless so didn't even think about it. Oh well there's always next time!
  6. tpt
    tpt
    9 May 2011
    819
    Thanks Received:
    155
    Country:
    if he went over old tiles he wouldnt have been able to get the trim back to the wall anyway would he?
  7. Richard C
    Richard C
    26 Apr 2005
    10,625
    Thanks Received:
    999
    Country:
    How’s he finished the ½ tile? can’t see from the pics.
  8. johnagall
    johnagall
    11 May 2011
    118
    Thanks Received:
    London
    Country:
    I don't understand what you mean mate. :oops: :oops:
  9. Sponsored Links
  10. johnagall
    johnagall
    11 May 2011
    118
    Thanks Received:
    London
    Country:
    Having only just looked at tile trim I see what you mean. Is retro fitting straight forward?
  11. tpt
    tpt
    9 May 2011
    819
    Thanks Received:
    155
    Country:
    not really! sticking it on after it never seems to sit properly.
    i'd be inclined to just 'point the edge with white grout and get a chamferred finish on that - richard\tictic what are your thoughts?
  12. tictic
    tictic
    6 Oct 2009
    1,419
    Thanks Received:
    172
    Glasgow
    Country:
    Try looking at gradus/shulter/homelux/genesis ect for tile trim you should get a PVC trim that will cover the two course off tiles about 15mm+...square/round edge etc and cut the back off and silicone it on.
    Rich the half tile...he as put the cut inwards...so not showing at edge. ;)
  13. tpt
    tpt
    9 May 2011
    819
    Thanks Received:
    155
    Country:
    yeah i noticed that...
  14. Richard C
    Richard C
    26 Apr 2005
    10,625
    Thanks Received:
    999
    Country:
    Well that’s what I thought unless he’d managed to get hold of some bevelled ½ tiles (never seen any can you get them?); got to say it’s not something I’d do, it must look very strange. I’ve done a few brick weave splash backs in plain rectangular slips & have black matt in my own kitchen but you need to think carefull about using bevelled edge. You can cut the bevel off on the internal corners which looks OK but open ends don’t really work & I can’t see how it will ever look good.
    As far as finishing off goes; I’m not a lover of trim, especially the plastic stuff, & tend to leave the tops/sides open & filled or finish off with border tile but, with tile on tile, the edge is going to be quiet thick. A tile border trim over the top might work but not sure how it would look with bevelled edge tiles & then there’s still the vertical edge!
    If you’re thinking of using bevelled edge tiles, you really need to think the layout through & how it’s going to look; brick weave only really works if you fill between two walls.
  15. paulpa
    paulpa
    18 Mar 2011
    283
    Thanks Received:
    4
    Berkshire
    Country:
    You could always frame with a decorative wood trim. Not ideal but would tidy it up. You can buy it from all DIY stores.,
  16. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
