    Dismiss Notice
Tilling bare plaster skim
Discussion in 'Tiling' started by vibrobullit407, 3 Feb 2012.
  1. vibrobullit407
    vibrobullit407
    3 Feb 2012
    765
    Thanks Received:
    52
    Blackpool
    Country:
    I am about to commence tilling my bathroom walls and was wondering what primer I would need for fresh plaster skim. I've checked my tile weight and they are well below the 16Kg/m2 recommended. I have a norcross tanking system for the shower cubicle but will I need to tank above the bath as well?
    Any advice would be greatly appreciated.
  2. Sponsored Links
  3. Richard C
    Richard C
    26 Apr 2005
    10,619
    Thanks Received:
    998
    Country:
    What material & size are the tiles?
  4. vibrobullit407
    vibrobullit407
    3 Feb 2012
    765
    Thanks Received:
    52
    Blackpool
    Country:
    The tiles are 4.5mm thick porcelain tiles (600mm x 300mm).
  5. prceramics
    prceramics
    18 Jan 2012
    84
    Thanks Received:
    7
    Buckinghamshire
    Country:
    do you have primer in your tanking kit ? the bal one comes with a small bottle
  6. prceramics
    prceramics
    18 Jan 2012
    84
    Thanks Received:
    7
    Buckinghamshire
    Country:
  7. vibrobullit407
    vibrobullit407
    3 Feb 2012
    765
    Thanks Received:
    52
    Blackpool
    Country:
    Yes it comes with a 500mm bottle but wont cover every where that I will be tilling. It will probably just prime the shower walls. Is there a decent not too expensive primer that i can purchase to prime the rest of the room (another 9M2)?
  8. vibrobullit407
    vibrobullit407
    3 Feb 2012
    765
    Thanks Received:
    52
    Blackpool
    Country:
    Its just skim and it was done over 2 weeks ago, would this not be plenty of time for the plaster to dry out?
  9. prceramics
    prceramics
    18 Jan 2012
    84
    Thanks Received:
    7
    Buckinghamshire
    Country:
    sorry skim will be fine
  10. Sponsored Links
  11. Richard C
    Richard C
    26 Apr 2005
    10,619
    Thanks Received:
    998
    Country:
    Depends; if it’s just a slim you’ll be OK to tile after 14 days. If it’s a base coat & skim, then 4 weeks is the mark. Don’t douse the tiles in water for 14 days after laying.
    For that size tile you must use cement powder addy, not tub ready mix or you could have problems with setting. You will need an acrylic primer to avoid reaction between the cement in the addy & gypsum in the plaster. Forgot to ask what the skim is over; if it’s boards use either Rapidset flexy or Single part flexy (SPF), otherwise use a Rapidset or a suitable modified addy with a longer set time.
  12. Richard C
    Richard C
    26 Apr 2005
    10,619
    Thanks Received:
    998
    Country:
  13. vibrobullit407
    vibrobullit407
    3 Feb 2012
    765
    Thanks Received:
    52
    Blackpool
    Country:
    Got me worried there! :eek: Taken next week off to do it!
  14. Richard C
    Richard C
    26 Apr 2005
    10,619
    Thanks Received:
    998
    Country:
  15. vibrobullit407
    vibrobullit407
    3 Feb 2012
    765
    Thanks Received:
    52
    Blackpool
    Country:
    The wall have just been over skimmed over previous skim.
  16. Richard C
    Richard C
    26 Apr 2005
    10,619
    Thanks Received:
    998
    Country:
    No problem
  17. Richard C
    Richard C
    26 Apr 2005
    10,619
    Thanks Received:
    998
    Country:
    Posts were all a bit quick there; if you’ve tanked it then the gypsum thing is not relevant but the acrylic primer is the same; it does pay to use tiling materials from the same manufacturer though
Loading...
Share This Page
