Help!
I found my new tilt and slide door got stuck.
I have two tild/slide doors, each slides to one side, and closing togehter in the middle joining each other. Now one got stucked, they just looked closed, but both cannot be opened.
The problem door's top is closed fine, and looked normal. But the bottom of the door is not closed and not fitted into the correct place, see attached picture.
So the problem door's handle is at 12 o'clock, and cannot be moved/turned, so it wont tilt. The other doors handle and be turned to 3 o'clock, but the door will not tilt because the problem door is blocking it.
Has anyone seem similar issue? Or know how to fixed it.
Any comments will be much appreciated, and also advice on who could help in this case(locksmith? Builders). Thanks!!
