tilt and slide door seems to come off the hinge at the bottom... HELP
12 Jul 2016
I have a tilt/slide balcony door. The one in which you turn the handle 90 degrees, and the top of the door tilts inwards to give ventilation. Turn the handle 180 degreed and the door pulls out and slides.
Earlier today the door was stiff sliding open so I pulled it a little too hard.
When I closed the door again I noticed it sounded as if a window was open. On further inspection I noticed there was a gap along the bottom side of the door where it closes. The door handle also wont lock downwards into its normal position completely.
Please tell me there is some way of fixing this without having to pay for someone to fix it??
Thanks!
slide the door and try to turn the handle several times.
How about the hardware warranty ? Can you read the logo ?
Tilt and Slides are potentially lethal in my opinion!! , there is normally a tab for locking on one of the lock plates , which may need pushing in to move the handle to its correct postion. It is also entirely possibly it is not running on its track and could need lifting back on
