Timber frame garage.
If the wording of a statute is ambiguous, how would anyone actually know if they were breaking the law?
This one is not ambiguous.
Only a judge could pronounce on the interpretaion, and why should anyone risk going to court over a statute which is imprecise? In this particular case, the law is indeed an ass.
In this particular case, if the OP does not know that his building will be constructed substantially of non-combustible material then he submits a BR application - it's that simple.
If designers are not 100% certain and building control are not 100% certain, then according to Bas no work should be carried out, no matter how important or trivial, unless every aspect is tested in court.
Really? And I've said that where, exactly?
Is this your take Bas?
I would ask you to show where I have said that, or anything which an idiot could interpret that way, but I fear that is pointless as I think you can barely read.
You didn't. I'm asking your opinion.
So....
Is it your take on it Bas?
P.S I can get a grown up to read your response to me.
Fail to see what all the fuss is about really, as the OP has not given the distance from his boundary.
The OP clearly states in his post that garage is within 2 metres of the boundary, which being the case and providing he is not 1 metre or less, then he can do what ever he likes.
Curious to what BAS will say to that.
Regards oldun.:LOL:
I'm not sure what ban all sheds is on about, I get what he says in principle, but it is not what actually happens.
Timber frame, clad with non combustible fire resisting materials both sides, that's what is done all the time and building control are happy with. Haven't come across any situation where they demanded the timber frame was swapped for masonry, they normally just want your X hours fire resistance and X surface combustibility rating, cladding it achieves both.
Technically if you insulate between the studs with mineral wool, the timber frame is then considered only 10-15% of the wall, though I suspect that is more relevant to thermal calculations, it can relate to fire and that would give you your "substantially constructed of".....
I'm not sure what ban all sheds is on about.....
Join the party.
Precisely.
Exactly what I was thinking when you consider things in weight also. I reckon the roof tiles on a timber clad structure are a "substantial" part of the structure also.
Bas says "YOU MUST NOT BREAK THE LAW" and that is pretty much it, without any consideration for interpretation. A bit blinkered me thinks.
If the OP does not understand the meaning of 'substantially non-combustible', then neither will the building inspector, because they both speak English.
You could look at the issue the other way round: let the OP build his timber garage, and if the inspector is not happy, then he can serve a s.36 notice. But the council won't do that, because they will be just as unsure about the outcome of an appeal as the OP.
Regards oldun.:LOL:
What I say is that it seems clear to me that it will be on the boundary:
I've now realised that my plans to build it off the existing garden wall are no good, as not much is holding it up!
So I would like to get rid of this wall, and go fully timber frame.
I'm on about that **** FMT telling the OP to ignore the law.
Not for as long as FMT is allowed to peddle his awful advice here.
All of that is only relevant if there is some official guidance the OP can rely upon to correctly show that his building is constructed substantially of non-combustible materials or if he seeks BR approval and gets agreement from them that it will comply with Part B.
You really, really, are hard-of-reading, whatever you think.
What the OP does is up to him - what I have been objecting to are people here TELLING him to break the law.
I know, but that's because you are a defective specimen of humanity, bereft of decency and morality.
