We have recently purchased an old cottage and the builder has recommended we remove the Pantiles and felt the roof. How necessary is this and are there alternatives ?
Pantiles can last around 120yrs - Felt depending on the quality can last between 15 and just maybe up to 25 years - which one would you want to rely upon??
If you want to spend some money, you could strip the pantiles, introduce some insulation between the rafters and retile - not quite that simpler an operation, but it is worth considering.
Has the builder said why he would suggest replacing the pantiles with felt?
why mend something that aint broken.i would felt your roof only when it leaks and if you dont touch the tiles then it shouldnt leak,assuming its not leaking at the moment.
If you do felt it,make sure you use breathable felt.
Yes - to clarify it's a 18th century cottage. I've totally stripped the inside because all plaster was shot. We now have an empty shell upstairs and can see through to the tiles. With no insulation at all.
What is being suggested is to remove the tiles, then lay felt and relay the same tiles. Which I'm happy to do if it is necessary but obviously would also like to avoid if it's not 'totally necessary'. Already from the answers I'm thinking if it ain't broke....
There were sections of interior plaster that looked like it had been affected by damp, loads just fell off, but it's impossible to tell how long ago and wether the issue was fixed or indeed if it was just 'old' plaster.
