- Joined
- 7 Nov 2023
- Messages
- 23,984
- Reaction score
- 15,666
- Country
That is exactly what it is.Its nothing like anything current, except it's an adjustable spanner
Yes rail nuts were and still are square used in high vibration situations and for strength. Steam fittings had the same type of nuts for strength too. Rail tracks still have them to this day.Looking at the depth of the jaw throat, Id say it was used for tightening square nuts, i.e railway issue.
John![]()
Even Hornby track!Yes rail nuts were and still are square used in high vibration situations and for strength. Steam fittings had the same type of nuts for strength too. Rail tracks still have them to this day.
Probably notEven Hornby track!
Looks gimmicky, whats wrong with the back end of a wide rake, a shovel or an old fashioned plank.I used a Spazzle for the first time today. It worked absolutely great. Brand new, made in Wigan. Proper solid metal with a wooden handle.
One of those things where you don't need tuition, you pick it up and it tells you how to use it. You use it to agitate concrete. Vastly superior to a plank or float, it's effortless to use and really pumps the stuff. Then you can use it to spread and level too.
Bulldog Alloy Spazzle 1520mm (60") | Toolstation
Need to level out loose material? With this Bulldog aluminium spazzle, you'll carry out top surfacing work with ease - the 600mm solid alloy blade is designed to graze across the surface and distribute concrete or asphalt evenly.It's more than just a concrete spazzle - use it to level out...www.toolstation.com
They are ok for certain jobs. We tend to bypass that type of tool and use a rake, a tamp and a bullfloat on large slabs. It has a tilt bracket and takes some getting usead to....Looks gimmicky, whats wrong with the back end of a wide rake, a shovel or an old fashioned plank.
It's vastly superior, in a way that can't be described without trying one.Looks gimmicky, whats wrong with the back end of a wide rake, a shovel or an old fashioned plank.
To what exactly?It's vastly superior
They are ok for concrete garden paths and such like.Looks gimmicky, whats wrong with the back end of a wide rake, a shovel or an old fashioned plank.
I reckon Meccano, That had square nuts...Even Hornby track!
