At the very least get them switched by relays so that your littleun is only switching say 12v or less, I'd recommend SSR's controlled at 3 or 5v.
Good point Tim.
How would I transform down to 12 volts?
bolt them to the wall and use mains lamps, but you are still going to need a controller
Have you a link for a controller pls![]()
...............But first of all you need to get clicky and make it up, it does need soldering, but it does come with instructions.
i'd be a bit apprehensive of a 5 yr old playing with light switches with 230v across them.
Rf are you really making it? if so, how about put some triacs on it, switched by the led out put, that way it can then switch the mains lights
I'd suggest using Solid State Relays AC mains rated output DC Controlled input 3V run from a battery source say 3VHow would I transform down to 12 volts?
A lot of my switches at home are X10 controlled no need to touch themSo what voltage are the domestic light switches in your house![]()
Good point Tim.
