Trianco Eurostar wm not working
18 Nov 2013
Yorkshire
Hi. I have a trainco wall mounted oil boiler. It is a standard fill from header tank system. The boiler fires and heats only about 2 m of pipe work. The pump and 3 way valve are all ok. I have drained it off until empty and re filled it but still no good, could it be fured up? I'm at a loss
More info needed, does it lockout and need to be reset, or does it get to temperature and switch off?
Hi Paul. No it does not lock out, it gets to temperature then shuts out. After a while it starts up again I guess due to the water cooling down. It seems to heat the water to around 2m of the pipe. The boiler does sound likes the water is hissing inside just after it cuts off. No other noises though. I thought it was circulation but I changed the pump and valve. I also bled the system
Are you sure the pump is working? Have you bled the pump?Otherwise, you must have an airlock.
System and boiler off, undo big silver screw on pump with flat blade screwdriver untill nothing but water comes out.
Have you bled any bleed points on the pipe work?
Cheers. Last time I bother you. I bought a second hand pump and fitted it. Could be bad luck that that one was also knackered. I ran all the water out the system and it ran fairly clear and also filled up ok
Yes you can have clear water and still have a blockage.
Second hand pump. Well asking for trouble.
Still the pump or a blockage.
