M
marsaday
I have a normal steel trowel for plastering (£7 approx), so not a posh marshaltown etc.
I noticed the trowel is leaving one fine line when i go on an upwards sweep, but nothing if used the other way.
I could not see any grit on the trowel so assume there is a blemish in the metal.
Can i sort this problem out ? Do you use sand paper to rub the trowel down to get rid of any contanimation.
